5.5 deg of caster to much?
Old Mar 26, 2013 | 08:46 AM
Kojack's Avatar
Default 5.5 deg of caster to much?
I am trying to figure out my caster, i am looking at getting a set of fixed length synergy LCA. they will net me about 5.5 deg of caster with my leveling kit, would that be too much?
Old Mar 26, 2013 | 09:00 AM
kjeeper10's Avatar
Vet Army
No that is fine. With little lift and stock shaft 5-6 is ok
Old Mar 26, 2013 | 09:10 AM
Kojack's Avatar
awesome.
I have my alginment specs here and my caster right now is 3.4/3.3 I need it increased. did'nt think a leveling kit would toss it that much.
Old Mar 31, 2013 | 11:39 AM
kjeeper10's Avatar
Vet Army
No jeep is the same. You could have been at the lower end of spec from the factory.
You will benefit greatly with a little bump in caster.
Old Mar 31, 2013 | 11:56 AM
SpicedCrusher's Avatar
Spend the extra couple dollars and get adjustable arms rather then fixed.
Old Mar 31, 2013 | 12:19 PM
JK Inspired's Avatar
As one replied, all wranglers are different, so, you may not need adjustables.
Old Mar 31, 2013 | 02:31 PM
Kojack's Avatar
Don't need them, I'm never going any higher than what I am now.
Old Mar 31, 2013 | 02:38 PM
JKSJSPEC fixed length lower control arms have clevite bushings and are 3/8 of an inch longer than OE and got me 2 degrees of caster back.
Old Mar 31, 2013 | 03:03 PM
pcmasten's Avatar
Veteran: Marine Corp
Famous last words!
Old Mar 31, 2013 | 03:39 PM
Gman*2007's Avatar
Adjustables are better, that way you can get that happy medium between the drive shaft angle and caster. Too much caster may cause vibration from the drive shaft.
