Stock Rear Bumper is a 10 Gallon Water Tank
Check out the Write Up!
https://www.jk-forum.com/forums/jk-w...9/#post3503735
Well almost... About 9ish.. But yes, it holds that much, and securely. There is 4 drain holes you need to plug, and you can fill it up. Reason I say this I was looking at options for onboard fresh water for cleaning up ext. I was going to use Gerry cans, but I saw the hollow bumper as a waste if space so I gave it a shot! Next I am going to get a pump and hose and I'll have running pressurized water! Great for use as a expedition modded jeep! For rinsing off, shower, cooking, washing mud off windshields! Great thing to have!!
Not to sure if the bumper could be sanitized to use as drinking water too? Let me know what your guys thoughts are! Any pump ideas?
But then again if it has drain holes syphoning it into a bucket would be a waste of time, mabey a battery operated pump such as a water heater draining pump, im not sure if they come battery operated though
, you could always keep a length of hose and use the ol syphon technique
