Getting 2.5 MT RK Lift for 2 Door 6S Sport 2010, what else do i need?
I am going to buy the 2.5 Max Travel Rock Krawler Kit and i am trying to figure out what else do i need to get. I have a 2010 jk 6 speed sport manual trans, flat fenders. I just want to use it a littleeeee offroad and but mostly DD. Here is a list of what i think i am supposed to have, if you can confirm if i really do need it and anything else i would really apprechiate it. Do i need a new drive shaft? for front or rear as well? Anything else? Thanks!
TeraFlex HD VSS Steering Stabilizer
Part #: TF-1513001
TeraFlex Rear Lower Bumpstops, Pair, (For 3" or Higher Lifts)
Part #: TF-1954700
TeraFlex Fox Racing Shocks 2.5"- 4" Lift - Rear
Part #: TF-1982819
TeraFlex Fox Racing Shocks, Front, 2.5"- 4" Lift
Part #: TF-1982820
TeraFlex Front Upper Bumpstop 2.75" Tall Pair
Part #: TF-1953800
Part #: TF-1513001
Part #: TF-1954700
Part #: TF-1982819
Part #: TF-1982820
Part #: TF-1953800
I have the same lift and replaced the DS when I had the lift done.
You will just need shocks and bump stops. Don't need a steering stabilizer unless you broke the factory one. If it's not damaged, relocate it before it does get broken.
You will also need disconnect pegs (place for the disconnects to go when disconnected). RK doesn't include the pegs. You can zip tie them though. Think I added Teraflex pegs.
You don't need a new steering stabilizer but I would look into moving it up a bit. You should not need extended bump stops to run 35" tires with trimmed fenders, it will depend on the compressed length of the shocks you get and the back spacing on your wheels.
Measure and install bump stops after you have your suspension installed and are able to cycle it to see what you need.
