High steer knuckle / tie rod flip
Has anyone successfully flipped the tie rod onto the top of the arm yet? Are there plans for a knuckle with greater separation between the tie rod and drag link arms?
One or two companies are doing the drag-link, but none that I know of have figured out a way to flip the tie-rod. I'll be doing this also, but I'm waiting a bit to see if anyone can come up with a drag-link & tie-rod combo.
BTW, if you flip the drag-link, you also have to move the trackbar to match the angle of the drag-link and avoid bump steer.
js.
js.
I have the Rubicon Express high clearance drag link (not installed yet) and was thinking about doing the same thing. It appears to me that it could possibly be done with 3/4" rod ends and a custom bent tie rod made of DOM.
