35's and 5.13 or 4.88 gears?
Old Mar 30, 2013 | 02:36 PM
Jsias's Avatar
Default 35's and 5.13 or 4.88 gears?
I have a 2009 JK Unlimited X (4 speed auto w/OD) with 3.73 gearing. Will be adding a 2.5 TF coil lift to run 35's. In terms of MPG and power would it be better to re-gear to 4.88 or 5.13? This is also my daily driver. Any feedback is greatly appreciated!
Old Mar 30, 2013 | 02:39 PM
pcmasten's Avatar
Veteran: Marine Corp
I run 5.13 gearing, 35's and a lift w/ auto on a JKU. I get about 12-15 mph around town and about 16-17 on the freeway. It's still slow going uphill. Go w/ the 5:13's.
Old Mar 30, 2013 | 02:50 PM
Jsias's Avatar
Thanks for the feedback pc!
Old Mar 30, 2013 | 02:58 PM
bluebear's Avatar
X2....not my opinion but some will tell you that you don't even need to change gears
Old Mar 30, 2013 | 03:55 PM
Jsias's Avatar
Thanks blue! Will there be a noticeable difference if I don't re-gear?
Old Mar 30, 2013 | 04:10 PM
nthinuf's Avatar
Your best bet would be to just get the new 35's and drive it first. Turn the OD Off, and you'll get a decent feel for the freeway gearing you would have with 5.38's. (Divide rpm by .69 to get od off rpm)
As an example, using numbers from the rpm chart in the modified faq's and 34" as actual tire height for the 35's:
3.73 / 34" = 1781 rpm @ 70
O/D off = 2581 rpm @ 70
5.13 / 34 = 2450 rpm @ 70
5.38 / 34 = 2569 rpm @ 70
It won't be the same around town, but od off with 3.73 will be close to the feel of 35's and 5.38's, and just over a 100 rpm higher than you would have with 5.13's. (not taking bigger tires / lift into account, of course).
Old Mar 30, 2013 | 04:44 PM
nickcoleman's Avatar
Chart shows you the optimum gear ratios based on your tire size and transmission type.
Name:	Gear Chart.jpg
So, you'd want to be in a 5.13 or 5.38 with 35" tires ... choice would depend somewhat on the type of terrain you normally drive.
I'm in the Western Rockies with some fairly steep climbs between 5,000 to 7,000 ft on a daily commute -- for my area, I'd choose the 5.38. Texas is fairly flat, low altitude, so you might get by with a 5.13.
Think you'll find a 4.88 is a bit sluggish regardless of where you're at.
Alll In My Humble Opinion of course.
Old Mar 30, 2013 | 04:53 PM
bluebear's Avatar
For sure...3.8L is a dog let alone slapping on 35s and running stock gears. Good luck with the build and post pics!
Old Mar 30, 2013 | 08:01 PM
Jsias's Avatar
Thanks everyone! Great info!! I think im sold on the 5.13 gears. Will post pics soon!
Old Mar 30, 2013 | 08:04 PM
Maertz's Avatar
I got 5.13s i wish i would have went 5.38..
