Economic Tire Carrier for 33" XD to solve rattle?
Old Apr 2, 2013 | 06:49 AM
mkrx5's Avatar
Default Economic Tire Carrier for 33" XD to solve rattle?
Hello all -
Have had 33" XDs mounted since I bought the JK 2 years ago and just recently started to get a rattle - first just for bumps and now its almost consistent, sounding like a screw is jiggling around against metal.
Needless to say, it is driving me insane so I took off the spare last night and oddly enough rattle was completely gone. I assume it maybe a broken weld? I had figured if it was I would still here it even without the spare on?
It is probably time for a carrier anyways. I want to keep the stock bumper and I dont think I need an adjustable as the tire fit just fine before. Since I do not do offroading and dont plan to, is the TF Hinge my best and most economic option? I hadn't planned on needing this so it is an additional expense i'm not looking forward to but I do not want to cause any damage to the tailgate.
Any feedback or suggestions is greatly appreciated. Thanks
Old Apr 2, 2013 | 09:22 AM
Hinrichs's Avatar
I was going to suggest the rancho bumper/carrier combo untill reading you wanted to keep your stock bumper.....i think smittybilt makes an oversized carrier that would probably be a good choice and is cheaper than the teraflex hinge. I think a few people on here run it. I think there are a few other options like that one just cant remember which they are. I know quadratech shows quite a few options on their site.
Old Apr 2, 2013 | 09:31 AM
gunbo75's Avatar
It sounds like the hinges are loose open the tailgate and lift it up and down and see if it is that's what happened with mine so I went with the Teraflex tire carrier and I love it good luck
Old Apr 2, 2013 | 10:50 AM
mkrx5's Avatar
thanks I will look at the hinges - can they be tightened?
I wish it still made noise after the tire was off because now I have no idea what was rattling or why. I may put the tire back on and drive around with a buddy in the trunk to try and pinpoint it. this is a huge pain!
Old Apr 2, 2013 | 10:52 AM
mkrx5's Avatar
do the tire carriers that solely mount on the tailgate make a difference? I was under the assumption i would need something that replaces the subpar hinges instead.
Old Apr 2, 2013 | 11:02 AM
suicideking's Avatar
I have the Smitty tire carrier, runs about $120. I have been running it for around 6 months with no problems. I have a 35" tire on it.
Regarding the rattling: Did you get the extended bump stops? If your factory bump stops don't reach the tire, that will cause rattling.
See: Daystar KJ09144BK - Daystar Tailgate Bump Stops for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
They can be trimmed to fit. If you buy the Smitty carrier, these won't be needed.
Old Apr 2, 2013 | 11:33 AM
demtek9's Avatar
I'm a fan of the OR-FAB carrier. The only rattle was my Hi-Lift and a bungie cord fixed that. Great tire carrier that lets you keep your stock bumper, but makes you drill a 1 inch hole for a mount under the driver side rear light. The only carrier I know of that doesn't require any modification is the Teraflex.
Old Apr 2, 2013 | 11:56 AM
mkrx5's Avatar
i do have the daystars and moved and never mounted them! need to track those down... what smitty do you have? That helps with rattle?
Old Apr 2, 2013 | 01:55 PM
PANGMAN's Avatar
I originally had the oversize Smittybilt tire carrier. The Smittybilt doesn't take the weight off the tailgate. It started creaking, but I'm running a 37" spare. I went with Terraflex now with the Smittybilt modded to fit. Couldn't be more happy.
Old Apr 2, 2013 | 02:12 PM
This: Smittybilt 2743 - Smittybilt Oversized Tire Carrier in Black for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
No rattle with a 35". If you get this, you won't need the Daystar bump stops. I want to eventually get a bumper/tire carrier. Mine might eventually rattle from weight. It's been rattle free for 6 months though. I think you'd be fine with a 33". Your rattle is probably caused by never installing the bump stops. Too much movement allowed.
Any pics? I'd love to see what you had to mod. I might end up doing this too since I already have the Smitty and the Teraflex hinge only costs around $400.
