Dana 30 inner axle seals.
OK, I have a 2007 with a dana 30 on the front and my inner axle seals are leaking and need to be replaced. Which should not be a tough job. The problem is that I have already installed the aftermarket superior seals into the axle tube
. So now it is going to be near impossible to pound the old seals out because of the tube seals being in the way
. Also i had to beat in the tube seals pretty hard so removing them will probably not be an option without destroying them
. Has anyone had this problem?? OR Does anyone have any ideas?? Any help would be appreciated!!!
Thanks,
Jeff
Thanks,
Jeff
