Painting coil springs.
Swapping out my X coil springs and shocks with a Rubicon equipment this weekend.
I'd like to paint the coils red. Recommended? If so what paint? Would the paint end up cracking from the spring movement?
I did the same to my two door. All you have to do is disconnect the sway bar, unbolt the shock, unbolt the brake line holder in the wheel well pull out old spring and install new one. Then re-bolt everything back and torque to spec
