Anyone Running an 09 Unlimited JK on 35" Tires with a 2.5" Teraflex Coil Lift?
Old Apr 4, 2013 | 11:34 AM
Jsias's Avatar
Default Anyone Running an 09 Unlimited JK on 35" Tires with a 2.5" Teraflex Coil Lift?
I called a local shop and I was told I couldn't run 35's on a 2.5" TF lift because of a problem with the rear tires. Has anyone run into a problem with this? I was certain I could run this set up. Information greatly appreciated! Thanks!
Old Apr 4, 2013 | 11:39 AM
Wahlsunlrubicon's Avatar
Well I have a unl 2011 and am running 35s with the TF 2.5 lift, and no issues here. I don't see what the difference would be but that doesn't sound right about the tires
Old Apr 4, 2013 | 11:43 AM
Joe_B's Avatar
They might be talking about the rear pinch seam rubbing your tires when your suspension is fully compressed. I run 35's on my 2010 JKU with the TF 2.5" coil lift. I did trim the pinch seam and and rubi rails to avoid this problem. You can run 35s and the lift without trimming the pinch seam on the road without a problem. Get the lift. I love it.
Old Apr 4, 2013 | 11:47 AM
JCurrent's Avatar
You need to figure out why they are saying this. 35s work with the 2.5" TF lift. It may be a backspacing issue with your wheels, or they might have the sway bar links installed incorrectly causing the tires to rub.
Old Apr 4, 2013 | 11:58 AM
Jsias's Avatar
Thanks for the info guys! I dont think these guys know what they were talking about...Im moving forward with this build, i have heard nothing but great things about the 2.5" TF lift. I cant wait to get it installed and run the 35's!
Old Apr 4, 2013 | 03:22 PM
hooper's Avatar
I have no problems with rubbing and didn't trim my pinch seam or rubi rail. You can also get upper and lower CA's and move your axle back a bit later.
Old Apr 4, 2013 | 03:24 PM
Jeek.OlllllllO's Avatar
You need wheel spacers with stock wheels
Old Apr 4, 2013 | 03:47 PM
Gina's JK's Avatar
I am running a Teraflex 2.5 BB and 315/70R/17 Duratracs.. Love this setup!
Old Apr 4, 2013 | 04:13 PM
BigDaddy's Avatar
I had an 08 JKU with the 2.5 spacer lift and 35" tires and had no issues. When I traded it in for an 11 JKU I had the dealer swap the lift and tires over and I have zero issues. I did trim both the pinch seam and air dam on both. The only issue I had was with the tires. I had Wrangler MTR's originally and quite frankly I ended up getting over 50k miles out of them and still had over half the tread. I just didn't like the ride and lack of snow traction. I swapped them out and went to Duratracs instead. WOW!! I love those tires! And the ride feels better than stock!
My wife now wants the same lift on her 11 JKU.
