TF Rear Uppers
Old Apr 6, 2013 | 11:21 AM
enash965's Avatar
Default TF Rear Uppers
So i have a 2012 JK 2 door w/ 3" lift and 35s. I put the front lower TF control arms to correct castor on and they turned out great. Everyone recommended rear uppers as well so I bought them and set them to the specified length which is as short as they go but when i went to install them and lined it up the axle had rotated so much to correct the pinion angle that the coil springs could almost fall out. I am running a stock drive shaft and the pinion angle really doesnt look bad. Do I even need the rear uppers?
Old Apr 7, 2013 | 06:30 AM
enash965's Avatar
Any help guys? If I don't need them I would like to sell them.
Old Apr 7, 2013 | 06:55 AM
RKracing's Avatar
1st.....On the Teraflex rear uppers they make 2 different rear uppers, 4 arm set up and 8 arm set up.
Hope you got the correct part numbers. 8 arm are 1" longer = not good in your set up. Check out their site to verify.
2nd..... A few companies make angled wedges for the rear axle.....RK, Senergy, and so on. One makes a plate set up.
Check this link out, hope it helps.
https://www.jk-forum.com/forums/modi...3/#post3392059
Old Apr 7, 2013 | 06:58 AM
enash965's Avatar
Thanks appreciate it. I bought them from a buddy of mine.
Old Apr 7, 2013 | 07:54 AM
rinkishJK's Avatar
Is your pinion pointed at your transfer case, or is it pointed downward? U would want to lengthen rear upper arms to correct a pinion angle issue. The rk wedges will help with the spring bow u will get.
Old Apr 7, 2013 | 02:41 PM
enash965's Avatar
Here's some pics i snapped of the rear coming off the trans to the differential
And here's the front meeting the differential
ID:	444087   Click image for larger version
Old Apr 7, 2013 | 02:44 PM
enash965's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=444086"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=444089"/>
Pics lines up weird. There's only one of the front.
Old Apr 8, 2013 | 12:21 PM
rinkishJK's Avatar
The rear doesn't look to bad at all. Did u measure the angles with an angle finder? U want to measure the angle on the bottom of the diff by the pinion, and on the shaft. U want the diff a few degrees down from the shaft angle.. Ie if the shaft is 30 degrees, make the diff at around 27 degrees.
The front will look like that, otherwise u will have a really low caster setting and the jeep will wander alot when u drive.
Only way to lessen the angles is get aftermarket double Cardon driveshafts which are longer and will lessen the operating angle on the joints.
