RK 2.5 Lift Install In 2 Days
Do I need anything else prior to my install? I get back home in two days from military training and would like to start my install since I will be on leave. Thanks ahead of time!
-RK 2.5 Stock Mod System
-(2) RK 2" Front Bump Stops
-(2) RK 2" Rear Bump Stops
-(4) Bilstein 5100 Shocks
-(4) Crown 5 on 5 x 1.5" Wheel Spacers
-(4) Crown SS Brake Lines
I have been reading that people end up needing LCAs or at least the RC drop-bracket. Also does the rear track bar bracket need to be welded since it is supposed to be a "bolt-on" kit? I just want this to be a smooth install. Any specific tools needed?
also will be installing
-Dynomax Evolution Competition Exhaust
-New Soft Top Tinted Windows
I'm in the middle of my RK 2.5 install right now. Here are some handy threads I've started/participated in on this.
https://www.jk-forum.com/forums/jk-s...stions-270357/
https://www.jk-forum.com/forums/modi...r-lift-270559/
Hopefully these will help you out!
The instructions says you should weld the rear TB bracket before you first take it offroad. For me I have seen too many horror stories of rear TB brackets shearing off due to the undo stress/leverage. Personally, I would get it welded.
Optional items:
1)Rear extended sway bar links.
2)Front adj lower control arms-you should drive your jeep first after the lift and judge for yourself if it is needed.
For me I had an unused set of TF front adj control arms.Drove the jeep a few hundred miles with the stock arms then installed the TF arms. Wow what a night & day difference in the driving and steering feel...
Optional items:
Optional items:
Optional items:
In my area it's $90 per hour....
We definitely recommend welding it prior to any off-roading adventures! Most of the bolt on ones we have seen are just fine on the street! But, that is not what we are all about!
Do not hesitate to give us a shout! We are here to help!
RK
RK
Thank you for the advice RK! I will definitely get it welded once I get back to Ohio and find someone trust worthy!
