Auburn Ected Locker
Old Jan 28, 2008 | 10:02 PM
cim330's Avatar
Default Auburn Ected Locker
Thinking to upgrade my sahara with the auburn ected locker, would like to hear some comments first
Old Jan 29, 2008 | 05:41 AM
HULKGREEN's Avatar
I read in a magazine article ... If you are using it for Hard wheelin it has a tendency to break ...... It's downfall is all the " SWISS WATCH " like parts in it !!!
Old Jan 29, 2008 | 06:31 AM
jared1843's Avatar
Default Aussie
Aussie lockers are cheaper, and i've found that mine is indestructible so far...
Old Jan 29, 2008 | 07:32 AM
cim330's Avatar
I want the ability of selectable.. other than auburn, what can i go with?
btw, no plan to do crazy off-roading...
Old Jan 29, 2008 | 11:03 AM
cim330's Avatar
Old Jan 29, 2008 | 11:18 AM
seer1's Avatar
OX makes a highly regarded locker for the D30. If you're aren't too worried about all the extras, ARB is also highly thought of. You could also order a Mopar Performance Dana 44 front axle replacement for your D30. All seem like pretty good choices.
Old Jan 29, 2008 | 02:05 PM
Blue's Avatar
The biggest thing I don't like about the Auburn Ected and Detroit Electrac is that when not engaged, they are still functioning like a ls, a truetrac in the case of the electrac.
With a selectable, I like for off to be, off . . . or open if you will. That's what makes the ARB, Eaton E-Locker and the Ox more appealing.
However, people have successfully put the Ected in the JK D44 by drilling out the bolt holes on the Ected for the ring gear bolts . I don't know if anyone has tried that yet for the Eaton Elocker.
Old Jan 29, 2008 | 03:23 PM
seer1's Avatar
From everything I've researched, the Dana 30 needs no mod in order to install a locker.
Old Jan 29, 2008 | 05:47 PM
cim330's Avatar
so you mean they are not direct fit on D44?
Any are direct fit??
Old Jan 29, 2008 | 05:52 PM
montejeep01's Avatar
the carrier needs to be drilled so the bigger bolts can be used with the arb's
