A good affordable lift.
I'm looking to fixing up my lift...had RC performance and I am not to pleased with it.. I was thinking of going with bilstein 5100's but not sure what springs to go with...maybe evo plush ride? and also how much of a lift can I go without having to put more into it...I know I'll need brake line extensions. but my plan was 1.25 body lift with 2.5 lift shocks and will the 3" plush ride springs work? need some feed back please.
33's nearly fit stock. You might be fine without the spring lift, or only the spring lift and no body lift. You won't need both for 33's.
I would say forget the body lift and just do the 2.5 inch suspension lift. I doubt that you will need any extra clearance but if you do then trim the fenders. Most people run a 2.5 inch lift for 35's so with 33's you should be fine. What exactly are you trying to fix on your current set up? Is the on road ride not smooth? Based on the fact that you bring up evo plush rides and bilstein 5100 thats waht i'm assuming.
sorry had to.
