Best lift for my Rubi
Old Apr 11, 2013 | 06:47 PM
luggw1's Avatar
Default Best lift for my Rubi
I recently purchased a 2010 Rubi Unlimited and have been mulling the idea of a lift to get more flex and 35 at the four corners. This is my third Jeep, but my first Wrangler, so I new to this type of suspension. In looking through catalogs and web sites I've discovered that there are more options than you can shake a stick at: Long arm, Short arm, budget lifts, etc.
My goal is something that I can drive on trails rated at 5 to 6 - I'd probably never do anything more extreme than that - but I don't want to go too cheap at the same time. Also, my wife is handicapped, so I need to keep it where I can get here into it. 3.5" to 4" would be the max I'd want to do.
I'm guessing the budget approach is probably not the best answer. Between the short arm lift and the long arm lift what are the pros and cons? Also, I saw adds for three link and four link designs; again which is better? Finally, is there a brand that would be my best choice; one I should clearly stay away from?
Thanks in advance for the help.
Bill Lugg
Old Apr 11, 2013 | 06:53 PM
Flyer's Avatar
Been researching for a year, and ridden in many Jeeps. I think 2.5, 3.0, and the MAX should be 3.5. Even a 2.5 will easily fit 35s. I say look at the following, in no specific order:
AEV
Rock Krawler
Metalcloak
I chose Rock Krawler but would happily pick one of the others. I put my 35s on today (stock but new wheels) and am getting my lift on Monday.
Old Apr 11, 2013 | 07:18 PM
luggw1's Avatar
AEV
Rock Krawler
Metalcloak
Thanks for the info. I'd be interested in your opinions as to why the max should be 3.5. I tend to agree from a practicality point of view, but what are your thoughts?
Old Apr 11, 2013 | 07:46 PM
Flyer's Avatar
Why lift more than that and get into even more complications? You only need 2.5 for 35s anyway. In fact, my RK will lift more than 2.5 and to play it safe, I am getting new driveshafts (easily another $1,000 for a 1310/1350 driveshafts). Plus your center of gravity goes higher.
Old Apr 11, 2013 | 08:49 PM
ghostjk's Avatar
I have to agree with flyer. If you don't plan on going any taller then 35s why go bigger then a 2.5in lift. If 35s are your end goal, I would run a teraflex 2.5 coil and shock lift. This kit doesn't require new driveshafts, control arms etc. If you go to 35s, depending on what yr model you have you may wanna regear also to 4.88 gears. I'd sleeve and gusset the front end, regear to 4.88 if a regear is needed, run 35s on a 2.5 teraflex lift.
Old Apr 11, 2013 | 08:57 PM
Redsox23's Avatar
I have a 2011 jk sport just put eibach leveling & lift kit with bilstien 5100 shocks and aev control arm drop brackets. Rides great, maintained stock suspention parts and clears 35' s easy. super simple to do yourself!!
Old Apr 12, 2013 | 02:51 AM
Jeepnut67's Avatar
Question
2dr or 4dr?
Old Apr 12, 2013 | 03:04 AM
Kojack's Avatar
get a full teraflex 2.5" kit with arms. add 35's and have fun...anything higher your wife will not be able to get in. im fully mobile and I ahve problems getting into mine with 2" of lift.
teraflex is my choice for lifts for sure, great customer service after the sale.
Old Apr 12, 2013 | 04:30 AM
Redsox23's Avatar
Its a 2dr sport
Old Apr 12, 2013 | 04:38 AM
bo9roadking's Avatar
Bill Lugg
Sell the JK now. It will cost you way more money in the long run than you think when you start going down the modifications road. Keep the CJ and get a bigger truck.
Nice to see you on the forums Bill.
