RC 2.5 spacer lift require wheel spacers?
Just wanted to know if wheel spacers are required to run stock sahara 18" wheels with this kit. I don't think the BS is enough for what is required.
Spacers are only required in relation to the larger tires sizes, not the lift kits. Although, some lift kits due require spacers at the rear I believe due to the sway bar link bolts hitting the tires. What tires do you have? Need more info to answer the question.
