Bumper Build...How should I mount the Clevis (shackle D-ring) Mounts... with Drawing!
Hey all, I'm building a front bumper and I have a quick "what do you think?" for you guys.
SO here is the down and dirty. Front bumper build...
- 4x6x3/16 wall tubing for main bumper
- 3/16 plate added and mount (bolt on) location
- Added plate will be stitched welded and rosette weld to main bumper
- weld on mounts will be 3/4 to 1"
- I know how to weld!
- I know that through mounting the clevis mount is best, but not sure if I want them in so far.
- Aloha is cut out of the bumper.
- Clevis mount will be welded from inside of any flush mount with either a cut out or rosette welds.
What is the base plate thickness??? And wouldn't these be the same as surface mounting them. I have looked at the bolt on ones too...some look to be CNCed out of one piece. Others look to but just a mount welded to a plate.... to me that's the same as just mounting them to the bumper. No?
I am by no means a fab guy, but I am trying to learn. (on my bucket list)Here is my buld if you interested.
http://https://www.jk-forum.com/foru...pleted-212365/
