$160 to mount & balance ? whf
A national chain 4 X shop wants to charge me $160 to m&b 5 tires and wheels. They said its so much because, we will take the tpms out of your old ones and put um in your new ones. they also wood like me to hand over $30 for lug nuts, $15 for stems & $20 for lead for grand total or $225 w/o tax, Does this sound like a smokin hot, sign me up now deal to you guys too???? how m uch would you pay ?
I though all JK came with lug nuts. From what my installer said, the tpms equipment is kind of expensive and a pain to do(I dont have tpms). Sounds kind of high are they installing 35" + tires, price some other shops.
The tpms is simply the valve stem if you are reusing your old ones it is no big deal but if they are buying new ones that can add up they are approx $50-60 each.
If they are reusing your old ones all they have to do is unscrew them after they dismount the tire and they will come right off.
Sounds way to expensive to me.
David
David
I paid $75 for 5 17" 33's mounted and balanced which included swapping the TPMS over. It was also removing the tires from the old wheels and mounting them on the new. Oddly enough, you mentioned they are charge you for stems...but you need to keep the OEM stems to keep TPMS.
They're ripping you off. Laugh at them and walk away.
They are charging you $15 for new stems yet they are reusing your TPMS which are stems?
......are they drilling holes for the new stems so you will have 2 on each wheel
.....They are screwing you.....turn and run
