Rk sway bar links question for a newb
Old Apr 20, 2013 | 01:13 PM
Learo2000GT's Avatar
Default Rk sway bar links question for a newb
I have RK 2.5 flex kit with 35s on 2013 JKU Rubicon. Is there a way to set up the links to use the e disconnect with out possibility of bending the links?
If manual disconnect is the best option what is the best way to secure the links and bars? I was reading to zip tie the links to the bar but can't figure out if I need to secure the bar somehow so it doesn't get caught on anything under flex.
Last question. What degree of angle for the sway bar is best for on road handling.
As always thanks for the help.
Doug.
Old Apr 20, 2013 | 02:33 PM
OH9JK's Avatar
JK-Forum Ambassador
Sway bar should be parallel with the ground for best on road performance.
The links and sway bar can be zip tied to the frame while off road.
Old Apr 20, 2013 | 06:50 PM
Perfect. That is the type of pic I was looking for. Thanks mucho.
