13 JKUR brakes
Old Apr 21, 2013 | 05:07 PM
05MoabTJ's Avatar
Default 13 JKUR brakes
I just finished installing the extended steel braided brake lines for my lift. What is the tiny line that runs next to the front factory brakes? It seems to be a sensor line. Jeep had attached it to the factory lines with a soft rubber ziptie. Can I remove it? The only thing I can do with it is ziptie it to the new lines to keep it out of the way. I have a 2013 jkur. Thanks.
Old Apr 21, 2013 | 05:10 PM
13WhiteRubi's Avatar
If I remember correctly from doing mine that should be the ABS wire.
Old Apr 22, 2013 | 05:32 AM
bo9roadking's Avatar
That wire is for the wheel speed sensor that the computer uses for ABS and traction control.
