GY MT/R with Kevlar 285/70/17's on stock 2012 wheels...will it work?
Old Apr 22, 2013 | 01:20 PM
CajunTiger's Avatar
Default GY MT/R with Kevlar 285/70/17's on stock 2012 wheels...will it work?
I just put some Nitto Trail Grapplers on my Jeep from the GY's listed in the subject. A buddy of mine has a 2012 JK Sport and has no idea what his back spacing is on his stock wheels, nor do I. Will these GY's fit on his stock wheels? I have some Pro Comp Extremes with 5" back spacing and had a little rub on the air deflector under the front bumper, but it was minor. I sold the tires to him, but we are worried that he might rub more than I did. Will it work?
Old Apr 22, 2013 | 01:32 PM
jk_sea's Avatar
The tires will fit on the stock wheels (285/70/17 being a rough 33" tire) but the backspacing will not be enough to keep the tires from rubbing at full lock and full flex. Compensate with a set of Spidertrax and you're good to go.
Old Apr 22, 2013 | 02:26 PM
CajunTiger's Avatar
He won't be flexing or at full lock. He is planning on lifting it, but he won't be offroading to hard. More of a hunting Jeep and towed behind his coach. I don't know if he will go with Spidertrax or not. Thanks for the info bud!
Old Apr 22, 2013 | 04:10 PM
Ryan0260's Avatar
X2 on the spacers. Spidertrax are good ones.
Old Apr 25, 2013 | 02:28 AM
Icehousesyd's Avatar
I am in the same boat. I want to lift my whitey, but don't want to void warranty. I have a 2013 jku sport and want to put bigger tires on first til I lift it. I have the 16" steel rims, and want to know the biggest tire I can put on it without spacers. Also don't want to have to buy another set of tires once I do lift it. Help help
Old Apr 25, 2013 | 09:05 AM
CajunTiger's Avatar
The tires worked out fine. No rubbing at all.
