Check gears
Calling jeep with the VIN is probably the best way. However, I have read on here that you can jack ip both back wheel and count the number of rotations of your wheels and compare to the number of rotations of your drive shaft. Maybe someone that knows details will post here.
Jack a front tire off the ground.
Rotate it by hand 2 revolutions, while counting the drive shaft turns.
If the drive shaft turns about 3¼ turns, you have 3.21 gears.
If the drive shaft turns about 3¾ turns, you have 3.73 gears.
Go here and register your jeep on the Owner's Center
https://www.moparownerconnect.com/oc...nersLogin.aspx
Create an account and it will provide you with the window sticker off your jeep along with various other informations such as recalls and service interval info...pretty cool and its free
