5.13's with 33"s
Old Apr 25, 2013 | 07:37 AM
Sargejk's Avatar
Default 5.13's with 33"s
Anyone here running a JKU-Automatic (D44/D30) with 5.13 gears and 33” tires? I’m really tempted to do (instead of 4.88’s). According to the chart, 5.13’s will lower my highway RPM’s from the way I’m driving now with the OD off with 3.73’s. If you have this setup, do you like it?...or your opinions
Old Apr 25, 2013 | 07:51 AM
kh202's Avatar
Sounds to me like a LOT of gear for 33's if you're not planning on going bigger.. just my opinion. Keep in mind, those charts are based on actual tire diameter. Chances are, your 33's don't measure 33". Have to take that into account and how much highway driving you do.
Old Apr 25, 2013 | 09:44 AM
JK Inspired's Avatar
255/80/17 (32.5 actual) and 4.88s are perfect. Some "experts" say THAT is slightly over-geared.
Old Apr 25, 2013 | 09:54 AM
kh202's Avatar
Yup. All depends what kind of driving you have to do on a daily basis.
Old Apr 25, 2013 | 10:01 AM
TURTLECON's Avatar
Sounds like overkill for 33s. If you plan to go bigger (like in the next 6 months), get 5.13s, but if not you'll prob feel like the Jeep is "over-driving" if yaknowwhatimsayin
Old Apr 25, 2013 | 10:04 AM
janders82's Avatar
I'm running 5.13s on my 2010 JKU Auto with 295/70/17 Trail Grapplers. Love he set up. Figured I would only want to regear once. Have no regrets. I'm sitting somewhere around 2600rpm at 70mph. Kind of hard to see, but here's a pic of the tach at 70mph
Old Apr 25, 2013 | 10:43 AM
nthinuf's Avatar
Ran 5.13's with 33's (d30 front), and now running 5.38's with 35's (d44 front). It's a personal choice, but I think it is hard to over-gear these 3.8 auto's..
The only 'problem' I have is high rpm's pulling heavy loads OD Off. With this gearing, I would probably be fine running OD On, but I'd rather err on the side of saving the transmission.
Old Apr 25, 2013 | 02:38 PM
Sargejk's Avatar
Default 5.13 w/ 33's
At 70 MPH (where I occasionally drive) I’m doing about 2,900 RPM now with my overdrive turned off. My current “33’s” measure about 31.5” and I plan to go to a tire that would be at least a full 33 inches or so, perhaps Maxxis Bighorn 305/70-17, which should yield about where I looking to land. It’s a DD and I just have no interest in going the 35” route. Anyway, 2,600 seems livable plus better low-speed and crawling throttle response.
Old Apr 25, 2013 | 02:59 PM
JKJeepJunkie's Avatar
I don't mean to jack the thread but can someone tell me how hard it is to do gears yourself
Old Apr 25, 2013 | 03:30 PM
Tweakecho's Avatar
Attachment 451014
my god man you did 137MPH in your jeep.... I did 106 and thought i was gonna die for sure... though i have a soft top and that was noooo good...
