2013 Lift Question
Old Apr 25, 2013 | 03:33 PM
Kohlbrenner70's Avatar
Default 2013 Lift Question
Hey guys. I'm looking into getting a lift on my 2013 JK. I want to get a 3.5 or 4.5 Rubicon Express lift with 35" Baja Claws on stock rims. I want to know everyone's thoughts on which size I should go with and if I'm going to have to do any other mods with the lift (i.e. drivetrain). I have looked into this multiple times and can seem to find any straight answers. Any info would be appreciated. Thanks!
Old Apr 25, 2013 | 03:44 PM
matprovo's Avatar
You will need new front and rear drive shafts with anything 3" and up.
Old Apr 25, 2013 | 05:53 PM
Jeeping4Fun's Avatar
3.5" for your 35's. wheel spacers for your stock rims. Coast 1310 double cardan front ds only. Crown extended brake lines instead of relocation brackets.
Old Apr 25, 2013 | 05:55 PM
One more. Do yourself a favor and do the grade 8 bokt kit from NR at the same time
Old Apr 25, 2013 | 07:15 PM
matprovo's Avatar
I'm pretty sure if its a 2 door he's going to need a rear drive shaft as well. The 4-door doesn't. I may be wrong though.
Old Apr 25, 2013 | 07:42 PM
Grn Jeep's Avatar
I just finished a 4 inch lift on my 2013, the front drive shaft is a must, the rear is not that bad.
Old Apr 25, 2013 | 08:45 PM
trouting's Avatar
I read a bunch on this as I also have a 2013 JKU and I'm getting ready to lift it. Everything I read states that you only need a smaller diameter front driveshaft if disco'ing.
Old Apr 26, 2013 | 04:35 AM
hooper's Avatar
Every lift is different. I have seen 3" lifts leave only 3/4" clearance between front DS and crossmember. If you lift does this dont expect that DS to last.
Old Apr 26, 2013 | 04:52 AM
Ryan0260's Avatar
This. I wouldn't go over the 3.5" lift for 35's.
Old Apr 26, 2013 | 05:52 AM
Josephrobby's Avatar
I have a quick question.. I'm on a 3 inch lift and my front driveshaft finally broke 2 weeks ago. For now it has just been removed thus making me a mall crawler. Anyway, I found a front d/s on Craigslist for 150$(thinkin I can get It for 100$) and it's for a 2013 rubicon unlimited. I have a jku x will it work?
