high clearance rear... 8"+ up and in 4“ on frame...
Old Apr 26, 2013 | 06:33 AM
BRUT4CE's Avatar
Former Member
Default high clearance rear... 8"+ up and in 4“ on frame...
Ended up using the stock frame cross member....
Ground out the frame rails from it and then used a extension hitch and cut off the length I needed...
Flipped the cross member over so it went up instead of down then notched it for the hitch....the pic of the hitch does not show all the gusseting and overlapped steel that was done....
Flipped it cut off the body mount pockets ground frame smooth and then put the cross member in, started the angles and plating I'll finish it tomorrow or Saturday.
Putting angles on it to slide off stuff and will do the sides after I finish plating in the inner sides...this thing will not move....
Here's how it started
Here's how it looks
28" from ground to hitch which is lowest part aside of frame rails
Giutted the rear jack storage to allow the clearance
This shows how far up flipping the cross me bear and then notching the hitch in gives you...its at least 8"+ higher now the ground clearance back there is huge.
Old Apr 26, 2013 | 06:39 AM
J3rs3yd3vil's Avatar
Neat idea! Clean work. Love the new lines, i was personally never a fan of the cross member look but you pulled it off
Old Apr 26, 2013 | 07:03 AM
helnbk's Avatar
I did something similar to yours. Cut the rear cross member off, and raised the hitch.
The lowest point of my rear bumper is about 3/4" below the frame rail.
The weight savings and approach angle is much better this way.
I went from a 140# spare tire and 160# bumper tire carrier, and this weighs in at 54#
Old Apr 26, 2013 | 07:31 AM
BRUT4CE's Avatar
Former Member
Yeah this is reinforced but light and the cross member is integrated into the bumper back so the hitch is less than 1/2" sticking out from the cross member but its raised almost 4" high than a stock cross member from being flipped...
Never done a plate bumper done lots of tubes on race trucks and pre runners so figured I'd give the angles a try....it is literally up there lol....its a minimum 8" Ill measure the factory bumper and hitch....
Old Apr 26, 2013 | 07:36 AM
BRUT4CE's Avatar
Former Member
You won't see the cross member its already partially plated in as a bumper....it will look like an extremely low profile rock bumper not a cross member at all....
Old Apr 26, 2013 | 08:29 AM
helnbk's Avatar
You've done a great job. I really like the minimalistic look of your bumper.
Old Apr 26, 2013 | 07:10 PM
BRUT4CE's Avatar
Former Member
Thanks...I'll be reinforcing and adding tow points to it....
Old Apr 26, 2013 | 07:38 PM
Deats4x4's Avatar
We're did you get the taillights from
Old Apr 27, 2013 | 12:36 AM
BRUT4CE's Avatar
Former Member
Made em...
Will be selling them soon , complete with lights or plates alone.
Old Apr 27, 2013 | 03:07 AM
ghostjk's Avatar
DAMN! That's awesome! Looks really good, high clearance, clean look. Very nice work
