Suggestions for adding additional lift to rear?
Old Apr 27, 2013 | 09:49 AM
sheepdog's Avatar
Default Suggestions for adding additional lift to rear?
I have the AEV 2.5 lift with 35s and full size spare. It seems the rear end of my 4dr is sagging lower than the front a little and doesn't look "balanced" to me. How can I add a little to the rear without a whole new kit?
Thanks
Old Apr 27, 2013 | 11:39 AM
dcharge74's Avatar
You've got two choices....
1> figure out how much lower the rear is and add a coil spacer
2> use this as an excuse to add an aftermarket front bumper and winch. That should even everything out.
Old Apr 27, 2013 | 07:01 PM
Ryan0260's Avatar
Bumper and winch will do the trick.
Old Apr 28, 2013 | 04:43 AM
hooper's Avatar
I added a coil spacer to mine. Or like they said^ the aftermarket bumper and winch should bring it level.
Old Apr 28, 2013 | 04:52 AM
sheepdog's Avatar
Thanks for the suggestions. I'm running an aftermarket bumper front and rear already. Time to look at some spacers. Any one type better than another?
Old Apr 28, 2013 | 07:26 AM
DKehler's Avatar
A spacer is a spacer. I've heard the poly ones offer a little softer ride than the steel ones but after I installed my poly ones I didn't think ny ride got any softer.
