Lift Kit Advice
Old Apr 29, 2013 | 01:18 PM
edgarg1223's Avatar
Default Lift Kit Advice
I have 20" rims with 33" tires with no lift kit and the wheels rub a bit when I make sharp turns. I want to keep the rims but I also want to make the tires 35". My question is how much do I have to lift my JK in order to have good clearance with 20' rims and 35' tires.
Old Apr 29, 2013 | 01:26 PM
Schwheelz's Avatar
How much are you wheeling? If its on the road you need to trim your air damn only.
Old Apr 29, 2013 | 03:52 PM
Smashboogie 4x4's Avatar
Former Vendor
It all depends on how much wheel it. If you want a good amount of travel you should go to a 2.5" lift. If you are only concerned about rubbing on the road and not on offroad then you can just trim the air dam as suggested above.
Old Apr 29, 2013 | 04:43 PM
TheDirtman's Avatar
Just add some wheel spacers, and trim the fenders no need for a lift.
