Just ordered RK 2.5 X factor
Old Apr 30, 2013 | 10:58 AM
nr6h's Avatar
Default Just ordered RK 2.5 X factor
I ordered RK 2.5 X factor with fox shocks and steering damper will be going with attitude mts
Old Apr 30, 2013 | 11:21 AM
mpkelley20's Avatar
Congrats! I didn't even know they made the xfactor in a 2.5". I run the 3.5" and love it. While a lot of people don't feel the need to have a full supsension system for 2.5", I think it is great to have so you don't have to deal with a lot of the issues people do end up having and then piecing together components to try and fix it.
Old Apr 30, 2013 | 04:56 PM
Smashboogie 4x4's Avatar
Former Vendor
Completely agree with you. 3.5" X Factor plus with the 2.5" coils. This set up performs amazingly!
Old Apr 30, 2013 | 09:18 PM
nr6h's Avatar
With the 2.5 RK coils I guessing Ill get about 3.5-4 in of lift on a 2 dr with stock bumpers and its my DD for now so I dont want to extreme but have it set up to bigger if I want to down the road
Old May 1, 2013 | 04:01 PM
nr6h's Avatar
I ordered the RK 2.5 x factor and ask for 2in bump stops but they shipped 3in will this be a problem and 4-6in fox shocks are those going to be to long on a 2 dr with stock bumpers and will be running 35s
Old May 1, 2013 | 04:56 PM
frostymarine's Avatar
2.5 x factor kit i just had installed with blistien shocks.
Old May 1, 2013 | 05:27 PM
mook8651's Avatar
Your shocks are fine RK lifts have more droup in them then most other an you actually need longer shocks in the front. If you get 2-2.5 for the front even with bump stops you will more likely over extend the shock an it will fail.
Old May 1, 2013 | 06:14 PM
nr6h's Avatar
ok thanks I just want to do it once and be done with it
