35" tires with a side of superchips
Old May 1, 2013 | 05:16 PM
Jkrgv's Avatar
Default 35" tires with a side of superchips
I'm getting new 35's and have a superchip programmer set at performance mode. I wondering if I need to buy the transmission upgrade mode? I worried the transmission would shift looking for gears. Anyone have thoughts. FYI 08 jku, auto, 3.73, 3" lift.
Old May 1, 2013 | 07:11 PM
Ryan0260's Avatar
The main thing is to calibrate the tire size correctly. It is what will correct the shift points. You may find keeping the overdrive off will help with your 3.73's.
Old May 2, 2013 | 02:59 AM
Jkrgv's Avatar
Thanks!, I did not know if I needed to spend the 39.00 for the upgrade
Old May 2, 2013 | 04:12 AM
Ryan0260's Avatar
It does allow more fine tuning, but can be somewhat tedious. It will allow you to change the shift points, whereas calibrating only brings shifting back to stock settings.
Old May 25, 2013 | 04:00 PM
Jkrgv's Avatar
New shoes!!! Beach time, excellent!
Old May 25, 2013 | 05:03 PM
frecks10's Avatar
What is the name of the grill you have ?
Old May 25, 2013 | 05:45 PM
Jkrgv's Avatar
Wild boar, around 275 primed
Old May 29, 2013 | 01:55 AM
Martinb36's Avatar
so tell me how does she run on the perfomance tune with the 35s?
looking very unique nice Jeep
Old May 29, 2013 | 03:01 AM
Jkrgv's Avatar
Still has good take off and highway performance is still good. Only drawback is the mileage went down 1 mpg. Had 265/70r17 before. These tires are quiet and gave me a soft ride. Went to the beach and they ate it up. As for being unique, thats why we buy them. To make them our own. Thanks.
Old May 30, 2013 | 01:17 AM
Martinb36's Avatar
just to check you still running 3.73 ratios on auto box. did the superchip make a good differance?
