Leaking top
Old May 2, 2013 | 03:10 PM
Rhawk's Avatar
Default Leaking top
If anyone could help my top seams to be leaking but only some of the time. Is anyone else having are have had this problem with jk?
Old May 2, 2013 | 03:28 PM
Atlacatl's Avatar
You and 90% of all hard top owners, myself included have this problem. Best thing to do is to take it to the dealership if its still under warranty and they'll perform a standard leak test. Depending on that they may replace the gaskets or tell u its a jeep thing if they can't reproduce the issue. There are a lot of threads on the issue, search hardtop leak and you'll get a lot if info... Good luck!
Old May 2, 2013 | 03:57 PM
Rhawk's Avatar
Thank you!
Old May 2, 2013 | 04:01 PM
madmike232's Avatar
I have had my rubber seal replaced about 4 times ... once a year , at the end of the day its just a bad design also make sure the front part of your top is seated right.... I find it funny how soft tops don't leak as much as hard tops lol
