what size mig ?
Old May 5, 2013 | 02:00 PM
ridg3runner's Avatar
Default what size mig ?
After a certain AZ company couldnt come through with thier products,, i've decided that I need to fend for myself. So, without breaking the bank, what size mig do I need to buy to weld plain old 1"sq tubing or cage tubing? Do I really need to run out and drop a grand on a welder I might only use once or twice a year? And does it really have to be a 240v ?
Old May 5, 2013 | 02:07 PM
Jonathan_JK's Avatar
If you have access to a Military base. The Auto hobby shop there has MIG TIG OXY/AcY and stick welders there. You can use them for a nominal fee almost free.
I'm a welder by trade and I prefer TIG welding. I have the control of the Amps, filler rods and speed . Generally TIG welds have better Penetration and look better. Others may say different but thats the style I'm best at.
Old May 5, 2013 | 02:10 PM
Patman's Avatar
No, you can get by just fine with a 135 or 140. I have a Northern Industrial 135 (gas ready) and can weld 3/16 in a single pass. Haven't tried 1/4, but it easily could with the right technique. I think mine was under $400 as well.
Depending on your budget, the hobart handler 140 is great.
Old May 5, 2013 | 02:19 PM
I'm only planning to build a trail rack or maybe some tube doors, probably nothing bigger than .120 or so. Was looking first at HF (let the chastizing begin) since it would be a beginner setup anyway.
Old May 5, 2013 | 03:25 PM
JKMARINE's Avatar
Go with the HF 90 amp welder. Screw everyone else! It gets the same job done for a fraction of the price.
Old May 5, 2013 | 04:41 PM
D_engel's Avatar
Spend the extra 100 bucks and get the 240v 70 amp mig from HF. I have it and its treated me very well. I do a lot with 1/4" material and it gets great penetration. Great product for the money.
Old May 5, 2013 | 05:08 PM
familytime's Avatar
JK Forum Regional Rep
x2,spend alittle extra and get a 220v unit.The 110v unit work great for sheet metal but not hot enough for plate.
Old May 5, 2013 | 05:18 PM
There's the answer I was looking for..really wasn't looking to use the 240 unless I had to but sounds like the better option. That unit comes with goodies too I believe, at least it was mentioned in the reviews that it did.
Old May 5, 2013 | 05:20 PM
JKMARINE's Avatar
You don't have a clue
Old May 5, 2013 | 05:28 PM
JKMARINE's Avatar
I welded some plate gussets on to my stinger and they are not sheet metal. Hmmm... It will work fine on tubing too
