How can I take this off?
Old May 7, 2013 | 03:33 PM
HAMMA's Avatar
Default How can I take this off?
Is there a way to safely remove it without messing up the paint? I have an eraser wheel, not sure if that would work since its not something "sticky". And i've tried soaking goo off on it, but it does nothing.
The VOID was left behind from Hawaii inspection stickers...
Old May 7, 2013 | 03:36 PM
Jonathan_JK's Avatar
goo gone or Goof off. They sell it at Wal-Mart in the hardware dept. And a credit card
Old May 7, 2013 | 03:40 PM
HAMMA's Avatar
I've tried goo off with no luck, but I actually just went out there when a credit card and made some progress. Thanks for the reply.
Old May 7, 2013 | 03:46 PM
GreenJK07's Avatar
Use a hair dryer or heat gun on low and heat the sticker up. It will come right off and so will the glue. Then use goo gone.
Old May 7, 2013 | 03:56 PM
Proy's Avatar
Hair dryer
Old May 7, 2013 | 04:20 PM
Huckleberryjeep's Avatar
hair dryer, wd40 and elbow grease
Old May 7, 2013 | 04:32 PM
Bootscraper's Avatar
AutoZone sells an adhesive remover made by 3M. It should work.
Old May 7, 2013 | 04:40 PM
HAMMA's Avatar
I have something called an eraser wheel which works wonders on double sided tape thats cooked onto paint... But I guess i'm a little worried to try it. It doesn't mess up the paint, so I don't know why im hesitant.
jk bobby's Avatar
lighter fluid does magic!
Old May 7, 2013 | 04:49 PM
GulfCoastJeeper's Avatar
I got some turtle wax sticker remover. Took off ecerything I needed it to
