Slight lean after off roading ?
Old May 9, 2013 | 01:46 PM
korps's Avatar
Default Slight lean after off roading ?
Disconnected the sway bar links went wheeling for the day went to re connect and had to drive up a lil on a ramp to get them both on.now the jeep is slightly tilted to the passenger side maybe a 1/4 inch. No wobble drives fine. The lift is newer. Did I just break in the shock and springs a lil more on the one side ?
Old May 9, 2013 | 01:49 PM
DesolationMania's Avatar
Assuming level ground, did one of your coils get unseated maybe?
