Please help! Air compressor
Old May 12, 2013 | 11:57 AM
Ironhead920's Avatar
Default Please help! Air compressor
I purchased the ARB high output onboard air kit. CKMA12/24 kit. i have everything wired up as it says besides the red-yel to Ignition and the blu-wht to dash illumination. Im lost… i can't figure out where these go and nothing is working. Please anyone help me out a bit thanks!
Old May 12, 2013 | 12:31 PM
MMXJKU's Avatar
The red/yel ignition wire can tap to the cig lighter. This wire triggers power to the compressor only when the jeep is running. The blue/white is the illumination wire that illuminates the little light on the ARB switch when the headlights are switched on. I don't recall which circuit to tap. Search the interwebs for the correct wire.
Old May 12, 2013 | 04:02 PM
On the cig lighter there's 2 wires there. A blue and a black. Do you know which one
Old May 12, 2013 | 04:24 PM
MMXJKU's Avatar
Should be the Blue with violet. I found a thread -
Project-JK.com - Jeep JK Wrangler Resource » ARB High Output On-Board Air Compressor Under the Hood JK Installation Write-Up
Old May 12, 2013 | 04:47 PM
Thanks! Although I still don't see that part in thrte
Old May 12, 2013 | 04:55 PM
MMXJKU's Avatar
It is in the comments. Also gives the illumination tap. Search the page for cigarette. Read the section below it for the illumination tap.
