removing my body lift *** I NEED HELP PLEASE***
Old May 13, 2013 | 03:14 PM
MFX's Avatar
MFX
Default removing my body lift *** I NEED HELP PLEASE***
I bought an Ace pro series rear bumper and things aren't lining up due to my M.O.R.E 1" body lift. I need to remove the lift but I don't have the factory body bolts or the 2 front factory body mounts. Is there anyone that has these parts for me?
Old May 13, 2013 | 03:30 PM
Quentin_T's Avatar
Is there not enough thread to just cut them?
I have always put a nut on, and cut flush with then back off the nut. That should help with the threads. If needed you can just file down the end to make them start easier.
Old May 13, 2013 | 03:42 PM
MFX's Avatar
MFX
I could always do that as a last resort. Regardless, I still need the original 2 front mounts. If I cut the bolts the body kit would be useless without hardware to anyone else that would want it
Old May 13, 2013 | 04:00 PM
Quentin_T's Avatar
The front mounts are OEM.
Old May 16, 2013 | 11:34 AM
MFX's Avatar
MFX
No mounts are NOT OEM and the supplied bolts that come with the body lift kit cannot be cut down due to insuffucient threading.
Bump to anyone who maybe have the 10 factory body to frame bolts
