A year and a half of opinions & research: Critique my Build
Old May 13, 2013 | 08:20 PM
mabaty's Avatar
2011 JKU Rubicon - AUTO
Daily driver: Wheels about 6 times a year, with camping and fire road exploration a few times a year as well.
Wheels: 16x8 - 4.5 BS (not 100% on brand yet)
Tires: 315/75-16 (~34.6")
Kit:
RK 2.5" Flex system (with front arms, and trackbar)
FOX 2.0 (1-3"lift) shocks
Teraflex bump stops
My biggest concern is whether I will regret not getting rear adjustable control arms (control arms are expensive!). I don't want the tires pushed forward close to rock rails, or rubbing. For every person that says I dont need it, another says I do, so i'm stuck on this a little. I want everything to look good, but functionality is my primary concern.
Thanks in advance!
Old May 14, 2013 | 03:12 AM
JK Inspired's Avatar
Install and then evaluate.
Old May 14, 2013 | 03:29 AM
blue project's Avatar
To properly dial in your lift you will want rear upper and fro t lower arms. They are a ton of options out there so price shouldnt be a big factor. Also consider front and rear adjustable trac bars to recenter your axles should you need to. Do t forget about your brake lines if you flex a lot. You drive a jeep...just empty every pocket.
Old May 14, 2013 | 04:26 AM
maximredriver's Avatar
Do the front LCAs, Rear UCAs , trackbars front and rear ,axle reinforcement brakets for the trackbars, and brake line drop bracket. It would also be a good time to upgrade to the Grade8 bolts for this stuff because getting these torqued to 125 ftlbs can be tiring.
It is pricy to do all this stuff at once but all these things serve a function for optimizing your lifted jeep's suspension.
At a minimum do the trackbars and rienf brackets, the other stuff can wait depending on the wheeling you do.
Old May 14, 2013 | 04:55 AM
Don't forget about the coil wedges and retainers, c-gussets and axle sleeves, ACOS, discos, and a wider rear view mirror so you can drive past and look at all of the misguided opinions on this forum.
Old May 14, 2013 | 05:05 AM
kh202's Avatar
Yup a truss or a sleeve and some gussets should be on that list asap. Even if you don't wheel it much, i would C gusset at a minimum. I got myself a PureJeep truss and gusset for $130 shipped
Old May 14, 2013 | 06:23 AM
helnbk's Avatar
Also, I believe that with a 16" rim, your choices of tires are less than if you went with a 17" rim.
Old May 14, 2013 | 07:52 AM
mabaty's Avatar
Thanks for the input everyone, why are the C gussets so important? Doesn't seem like many people are doing that?
Old May 14, 2013 | 07:58 AM
mpkelley20's Avatar
The inner C's are somewhat weak and are prone to bending...even with stock tires. The "mod" is much more popular than you think. It's just that people tend to do them with other axle reinforments at the same time and then everyone argues about which is better, inner sleeves, outer sleeves or trusses....so the gussets usually get lost in the conversation.
The cost of the gussets is pretty cheap depending on brand you get and maybe an hour or so of welding. Cheap insurance to protect your axle.
Old May 14, 2013 | 12:19 PM
You're right. I was joking about putting all the crap on. Some-several folks think that every aftermarket piece needs to be on their wrangler to adequately drive. Follow your gut and make it YOUR build.
