Who can install suspension for me?
Old May 14, 2013 | 04:16 AM
JKzoo10's Avatar
Default Who can install suspension for me?
I just purchased a 3'' BDS suspension kit and noticed in the instructions that welding is required. I dont have the ability to weld. They recommend a shop in Portage who was very rude to me when I called them to inquire about an install because I bought the kit online and not through them. Does anyone have a recommendation of someone in the Kalamazoo or SW michigan area that could intall this for me?
Old May 14, 2013 | 05:08 AM
Wood82ABN's Avatar
What needs to be welded? If you want to skip into Illinois there ate a ton of guys that would do it. Check out Chicagoland dirty deltas Facebook page. Ask and they will come.
Old May 14, 2013 | 05:14 AM
hooper's Avatar
The 3" lift for the JK does not need any welding. I would also get at least the front adj, LCA and not use the cam bolts supplied.
Old May 14, 2013 | 05:21 AM
kh202's Avatar
Just a friendly FYI, you maybe be better off wording it "who can HELP me install" I'd look for a local thread on here relevant to your area or find someone from a local jeep club that would surely help you out for some beer and pizza
PG-JKU's Avatar
I'm guessing the rear trackbar bracket?
