Gear Install vs. Gear and Locker Install
Old May 14, 2013 | 11:21 AM
KSARG1's Avatar
Default Gear Install vs. Gear and Locker Install
Ok so I just got a quote from Off Road Evolution for a gear install and they told me $999.99 for gears but it would be an extra $220 to install the locker that I already have. The wiring will already be setup for them as well. Can someone please explain to me why they are charging the extra $220?
Old May 14, 2013 | 11:25 AM
OnBelay's Avatar
Do they have to drill a hole in the differential to accommodate your wiring, or is that already done? If you've never had lockers in that differential, there are things they have to do.
Old May 14, 2013 | 11:31 AM
KSARG1's Avatar
They will have to drill a hole but at $220 that is one expensive hole.
Old May 14, 2013 | 11:39 AM
JKred's Avatar
They may have been planning on re-using the carrier and carrier bearings in that price, so the increase in price may be due to more materials.
If you're supplying all the materials tho that makes no sense.
Old May 14, 2013 | 12:10 PM
nthinuf's Avatar
double post ...
Old May 14, 2013 | 12:16 PM
nthinuf's Avatar
The $999 special uses all of your stock shims and bearings, correct?
The new locker might be getting a master install kit (new shims and bearings?), might require more time for setting up a new carrier vs re-using the same shims in the same order that they were removed, and time for the hole and maybe a drain channel?
At least to me, it would make sense for a different carrier to take more time/effort than removing a stock carrier and re-installing the exact same parts.
And if you do a little checking, you'll realize that people in other parts of the country are still paying $1500, or $2000, even $2500, for the exact same gear install you are getting for $1000. You might try not to piss them off worrying about the extra $220 for parts and labor...
Old May 14, 2013 | 12:41 PM
KSARG1's Avatar
$220 is alot of money to a guy like me. Oh and by the way I just found a shop to do the whole thing for $900!
Old May 14, 2013 | 01:37 PM
Tripletsi's Avatar
Cheaper doesn't always mean better... ORE is a premier Jeep 4x4 shop who stands behind their work, a real professional team who knows what they're doing.
Old May 14, 2013 | 01:39 PM
nthinuf's Avatar
Cheap isn't always better, do your homework on the new shop.
I went cheap for my 'first' new set of gears...
Old May 14, 2013 | 02:06 PM
raycn's Avatar
Brothers 4X4 in Montclair charged me $775 for my Eaton E-locker and another $350 for the install. They put 4.11 ring and pinion in at the same time for no extra charge.
