Quick question
Old May 14, 2013 | 01:01 PM
11JK_Lazo's Avatar
Default Quick question
I wanna put a 3.5 rubicon express lift on the question is can I still use my drive shafts or do I gotta get longer ones?
Old May 14, 2013 | 02:33 PM
SBEII's Avatar
It's not that they need to be longer but aftermarket shafts are smaller in diameter. It's likely your front shaft will contact your transmission crossmember at full droop. That will tear the rubber boot and the drive shaft will ultimately fail.
Old May 14, 2013 | 02:36 PM
Riznoy's Avatar
2012+ is mandatory, anything else is recommended, you can use your stock one for a bit, but it will fail at the cv joint.
