D30... Too Build or not too build
Old May 14, 2013 | 03:18 PM
thegoat's Avatar
Default D30... Too Build or not too build
If you are considering building a stock D30 axle instead of buying a ProRock 44, don't it is a waste of money and at the end of the day it will still be a D30. If you are considering the Rubicon D44, the axle tubes are the same as the D30, you get a bigger ring and pinion, but no added strength.
If you buy the ProRock 44 packed at Northridge 4x4 it will run you $4,950, if you build a Dana 30 it costs about $4,926. For an accurate comparison I put together a parts list that matched the Pro Rock 44, the D30 did not include the 1310 yoke, so it will more expensive. I hope this helps answer this age old question from a financial perspective.
[table="width: 500, class: grid, align: left"]
[tr]
[td][/td]
[td]Pro Rockk 44[/td]
[td]Built Dana 30[/td]
[/tr]
[tr]
[td]ARB Locker[/td]
[td]Included[/td]
[td]$1,040.00[/td]
[/tr]
[tr]
[td]Ball Joints[/td]
[td]Included[/td]
[td]$594.00[/td]
[/tr]
[tr]
[td]Gears, 5.13[/td]
[td]Included[/td]
[td]$252.00[/td]
[/tr]
[tr]
[td]1310 Yoke[/td]
[td]Included[/td]
[td]Not Included[/td]
[/tr]
[tr]
[td]RCV Shafts[/td]
[td]Included[/td]
[td]$1,185.00[/td]
[/tr]
[tr]
[td]Gear Rebuild Kit[/td]
[td]Included[/td]
[td]$150.00[/td]
[/tr]
[tr]
[td]Truss Kit[/td]
[td]Not Needed[/td]
[td]$250.00[/td]
[/tr]
[tr]
[td]External Sleeve[/td]
[td]Not Needed[/td]
[td]$155.00[/td]
[/tr]
[tr]
[td]Lockers & Gear Install[/td]
[td]Included[/td]
[td]$500.00[/td]
[/tr]
[tr]
[td]Axle Shaft Installation[/td]
[td]Included[/td]
[td]$300.00 (estimated)[/td]
[/tr]
[tr]
[td]Truss / Sleeve Installation[/td]
[td]Not Needed[/td]
[td]$500.00[/td]
[/tr]
[tr]
[td]Total[/td]
[td]$4950.00[/td]
[td]4926.00[/td]
[/tr]
[/table]
Old May 14, 2013 | 03:23 PM
Northridge4x4's Avatar
Sponsoring Vendor
Thats a pretty good chart you have! Prices on the 30 are pretty close could be a tad high but in my opinion makes perfect sense!
David
Old May 14, 2013 | 07:10 PM
Dynatrac's Avatar
Sponsoring Manufacturer
That is pretty spot on!!!
Do it once, do it right.
Old May 14, 2013 | 07:52 PM
big dr's Avatar
I love my Dyna's
Old Jun 28, 2013 | 05:13 PM
Dynatrac's Avatar
BTT.... because this is knowledge.
Old Jun 28, 2013 | 05:24 PM
GIJK's Avatar
Or you could add the artec for $250! https://artecindustries.3dcartstores...asp?itemid=312
Old Jun 28, 2013 | 05:47 PM
Dynatrac's Avatar
This is another option, but how many on here know how to weld? There's a lot of prep time and welding time into this truss, and that isn't a cheap investment much like C's or inner sleeves. It still doesn't address the castor or the clearance of a ProRock 44.
Old Jun 28, 2013 | 06:11 PM
GIJK's Avatar
Dynatrac I would never discount the the benefit of a new axle but to most of us $ is a factor.
Old Jun 28, 2013 | 06:12 PM
Lusky's Avatar
David
David,
How much would the front PR 44 be with a Tru Trac instead of ARB?
Old Jun 28, 2013 | 06:19 PM
Dynatrac's Avatar
Totally agree!
