LOD Rear Bumper Owners w/ Reverse Lights - Need into on the lights
To those of you with experience on this bumper, can you please let me know diameter of the lights used for the integrated reverse lights as well as the size of the opening? I really appreciate the help!
They are 4 inch round. The old gen you could use other lights instead of the Westin they sell. The new ones I think have changed so that the Westins are required when you order with the light cut outs. I had one special made to mount the 4" Engo LED in it from Chris at jeep add ons.
Attachment 457953
Attachment 457953
I am planning to get the LOD rear in a month or two, I've spoken to the guys down there and they said that if you send them the lights you want to mount in there that they will make the brackets for it without any extra charge.
Only tricky thing is the depth of the lights as there is not that much space, they recommended a certain model of rigid which I don't recall. You would need to contact them regarding the depth and you would essentially be able to use any light that fits that dimension.
