Recommended Tire Pressure for Street, Trail and Sand
Old May 15, 2013 | 11:18 AM
Desert Snow's Avatar
Default Recommended Tire Pressure for Street, Trail and Sand
I just put on some Nitto Trail Grapplers (295/70R18) via Discount Tire. I checked the pressure and they set it to 45psi and needless to say I feel every pebble on the street. So, my question is what does everyone set their tire pressure to for the street? And, while we're at it...what do you set your pressure to for rock trails, rock crawling and also sand?
Thx!
Old May 15, 2013 | 11:43 AM
Rob 12B1P's Avatar
I would drop them down to 35PSI and chalk test them for street. For trails/rocks/dirt I would start about 15PSI and see how they wrap and conform. For sand I would start at 10PSI and go down more only if necessary. On my old Jeep for sand I have gone as low as 6 pounds with 33x12.5x15's on 10" wheels. With the JK on the stock 255/75/17's I took them down to 10PSI in the sand and they were nearly riding on the rim so I went back up to 14PSI. I havent had the 37's in the sand yet so I cant comment on them.
Old May 15, 2013 | 12:51 PM
Ryan0260's Avatar
I would drop them to 30 psi and do a chalk test. I run mine at 26 psi cold.
Old May 15, 2013 | 12:54 PM
GentleGiant's Avatar
What is a chalk test?
Old May 15, 2013 | 01:10 PM
Rob 12B1P's Avatar
You run a piece of chalk or powder accross the tread and drive it to see if the tread is wearing evenly all the way accross the pattern.
Old May 15, 2013 | 02:56 PM
Thanks for the feedback. I just chalked the tires after setting the pressure to 32psi. In regards to the chalk test, how long do you run before noticing the wear? Is this something that would show after less than an hour of driving time or does it require more time?
Old May 15, 2013 | 02:58 PM
Rob 12B1P's Avatar
Should only need a couple hundred yards.
