towing with my 07 2 door
My dilemma: I was going to invest in a truck to do my towing/hauling but there's no way I can afford to have a truck and the jk. Well the Jeep isn't going anywhere, so I'll need to tow with it.
Now I plan on regearing to 4.88 and I'm on 35" tires with a 4" lift. And it's a manual transmission.
I'll be towing a 16' wells cargo enclosed trailer, with no trailer brakes.
I also plan on getting a 18'-ish boat as well. I can only assume that will have no trailer brakes either.
Anyone see any issues I may have besides lack of power from the 3.8 and the short wheel base? Nothing I can really do about those other than deal with it.
Dang, right at the limit with two jet skis? I'd probably be way over the limit with a 18' boat then.
Had a 1800 pop-up camper towed fine for the most part w/ and auto. You can definitly feel the weight push you around from time to time. I did upgrade to drilled/slotted rotors and hawak pads. Make a difference.
Yeah. One weighs about 800 lbs and the other about 600 lbs dry. 35 gallons of fuel combined between the two which is about 220 lbs. About 400 lbs for the double trailer, throw in some gear and I'm probably a little over 2000. It's always towed like a champ, those with pre-2012 autos should invest in a trans cooler and I've never felt like I needed improved stopping ability but I'm sure as mentioned in one of the above post it can help.
An 18' boat being towed by a 2dt JK with no brakes is wrong in every way. Figure out the total weights before you buy anything. The 2dr is not a towing machine in any way. You may be better off getting a 4dr JK or a crewcab truck if you really want a boat & use / tow it lots. Better to be safe than sorry when it comes to towing.
Kept the jeep and bought a Honda Pilot to pull camper.
I hear the 2013 has sway control on it. And the pentstar has more power as far as handling I'd figure it would be the same.
Hope this helps
I actually just picked up a Chevy c/c dually so we have a towing vehicle again. The JK is great for trails, but it's not meant to tow in any productive manner. Now that we've got the C/C we have more room than the JK & can tow the JK for wheeling trips once it gets built up to that point haha
