Teraflex 2.5 Coil Lift Issue
I installed the Teraflex 2.5 coil lift with shock extensions over the weekend. Now I am getting pop and rattle from the rear end.
I am thinking it is that stupid frame side rear track bar bracket that the template never lines up right for. My question is this: if I go to an adjustable rear track bar, are the factory mounts used? Or can I get the Teraflex axle side track bar bracket and remove the frame side bracket and use the factory track bar and frame mount point? Urrrgh.
I am thinking it is that stupid frame side rear track bar bracket that the template never lines up right for. My question is this: if I go to an adjustable rear track bar, are the factory mounts used? Or can I get the Teraflex axle side track bar bracket and remove the frame side bracket and use the factory track bar and frame mount point? Urrrgh.Hope this helps, feel free to PM me if you have any questions.
-Zach
I ordered that same kit, foreseeing that the frame side bracket causes problems I just ordered the axel side bracket also. For me this was the better option than getting a new adjustable rear track bar since I have no plans of going higher than 2.5" for my DD.
