Pitman arm neutral/ normal location
Old May 16, 2013 | 06:10 PM
GulfCoastJeeper's Avatar
Default Pitman arm neutral/ normal location
When your steering wheel and wheels are aligned properly should the pitman arm be pointing parallel with the jeep. I replaced my tie rod and draglink ends today and I think I may have my steering wheel off 180 degrees. My pitman arm is pointing a lot to my drivers side.
Old Jun 4, 2013 | 11:56 AM
Team Desert Eagle's Avatar
I think that your is in the correct spot. Mine is the same way.
Old Jun 5, 2013 | 05:26 PM
Smashboogie 4x4's Avatar
Former Vendor
To be totally sure set your wheel to straight ahead. Then cut it full lock one way and count the number of turns it takes. Then set it straight again and cut it full lock the other way. Count the turns again. It should be the same both ways.
