Heavy Aftermarket Bumper Side Effects?
Old May 17, 2013 | 01:57 PM
bfschor's Avatar
Default Heavy Aftermarket Bumper Side Effects?
Ok, it's finally come to replacing my bumpers (next on my list). Unfortunately, all of the bumpers I like are around the 70-80 pound range. When you guys replaced your factory bumpers with heavier ones, what kind of effects did you see? Was it that noticeable? I won't permanently mount a winch, so that extra weight won't be considered.
Sent from my iPad using JK-Forum
Old May 17, 2013 | 02:00 PM
k0260's Avatar
I didn't see much difference with my front, but mine is a fairly light weight Bestop Pavement Ends steel bumper. The rear I noticed sagged less than 1/2 an inch. No biggie.
Old May 17, 2013 | 02:07 PM
SpicedCrusher's Avatar
Just installed the JCROffroad Crusader stubby with skid plate on mine. Sticker on package said it weighed 83lbs. I forgot to measure a before and after measurement but I honestly can't tell if there is any sag or not. The ENGO 10k is going on this coming week so that will be the real test. I did however buy a 3/4 coil spacer just in case I do see a little sag but so far nothing.
Old May 17, 2013 | 02:12 PM
DesolationMania's Avatar
I wouldn't sweat it. 70-80 lbs is not going to drop you that much. Get two 40 lb dumbbells and lay them on top of your bumper. You're not going to see that much drop.
Old May 17, 2013 | 05:18 PM
lowendrider's Avatar
I added a JCR dagger stubby and a Milemarker with synthetic...around 130lbs. Beforehand, I replaced the front 14 coils for some 17s. It sits higher now than it did without the bumper/winch. Without the spring swap, my guess is I would have lost 1/2 to 3/4".
Old May 17, 2013 | 05:58 PM
Ryan0260's Avatar
A coil spacer will help to keep it level after adding the weight.
Old May 17, 2013 | 06:20 PM
Havoc55's Avatar
Read my suspension help needed post .
I don't know if any one else had as bad a problem as I did but mine was a nightmare.i did add a winch as well just be prepared to have to add 2 inch spacers to the budget.if your implying your going to use a receiver front bumper they are very hard to find.
Havoc 55
Old May 18, 2013 | 07:50 PM
bfschor's Avatar
Can you guys feel a difference in the on-road ride? Does the front end feel heavier?
Old May 18, 2013 | 07:52 PM
k0260's Avatar
I didn't notice any difference in handling or general ride feel.
Old May 18, 2013 | 09:36 PM
jaker t5's Avatar
I didn't notice much at all and even measure it one time I had it off
