Help new to the jeep scene
I just got a 13 jku and I was looking at this lift kit. I know theres allot of topics on these forums I just wanna get people opinion on this kit. Does this have everything id need to install and can I fit 35's under or even 37's? Any info is appriciated
http://www.quadratec.com/products/16502_4100_07.htm
AEV 3.5" DualSport RS Suspension System with Bilstein 5160 Shocks for 07-13 Jeep® Wrangler Unlimited JK 4 Door with LHD - Quadratec
I have the SC version of this kit which is the same except for the shocks. SC has non-resevoir shocks. Minevis a daily driver and I only do medium trails and touring. The AEV kits are great on the highways. I drove my Rubicon for 3000 miles before my brother and I installed the lift. I can easily say my jeep drives better than stock. I'm at 16k miles now and have never regretted spending the money.
There are lots of good kits that excell in different functions. The AEV has worked great for my Houston suburbia life with the occasional off road sight-seeing.
Good luck.
Good luck.
I had to get real honest my my needs and reality of my time off road.
I went AEV as it has the best reputation for onroad handling and will hold its own offroad.
The ride is subjective. It is a bit stiffer than stick but not uncomfortable. I've read another describe it as "euro-firm." I believe this is quite accurate.
All that said, I really have like my AEV 3.5 SC.
You can run a true 35" tire. 37" tires will require flat fenders if you disconnect offroad.
Sent from some string and a few tin cans.
Good luck.
Good luck.
Sent from my DROID RAZR using Tapatalk 2
If you even see your self going off road you might want to invest in a different kit that could be built off of. AEV is a nice product but is very expensive for what you get and not much room for improvement with out getting rid of parts that came with the kit.
Rock Krawler would be an excellent option that leaves tons of room for upgrades as your needs change.
PM us if you would like to discuss anything in detail. Good luck with your build and let us know if we can help you out along the way.
