2wd automatic swarbar disconnect?
Old Feb 1, 2008 | 03:14 PM
Bluewaterrider's Avatar
Post 2wd automatic swaybar disconnect?
Any one out there figure out how to get the sway bar disconnect to
work in 2wd?PLEASE SHARE!!!
I would love to get rid of the side to side head toss on uneven fire roads that do not require 4wd ......and in a lot of situations in 2wd if I could just get some more flex I would not even need 4wd.
OR IF ANY ONE HAS ACCES TO THE SERVICE MANUAL SCHEMATICS SEND THEM MY WAY AND I WILL GET ER' DONE ASAP!!
Last edited by Bluewaterrider; Feb 1, 2008 at 04:47 PM. Reason: mis spelling of 'swaybar'
Old Feb 1, 2008 | 04:11 PM
Originally Posted by toad
Actually, all you need to do is take some air out of your tires. Do you air down when you go on these "fire roads"? That may help.
NO, airing down on a hard packed uneven gravel road will not help with side to side movement.........but disconnecting the sway bar will.
I do air down on soft dirt roads, real 4wd only trails, and at the beach.
Old Feb 1, 2008 | 04:35 PM
atomicmecha's Avatar
since 70% of my off roading is in VA, i know what you mean. there are a lot of fire roads around that are bumpy as hell and have a lot of dips, but they don't need 4wd and disconnecting the swaybar will diffinitely help soften the ride. I'd look into this if i were you:
https://www.jk-forum.com/forums/jk-write-ups-39/full-control-lockers-swaybar-disco-25243/
i still have some issues to workout on mine with the dealer so i can't go mess'n with the electronics just yet. don't want them to find that i've been tampering with it and not warrenty the work even though it broke before hand.
Old Feb 1, 2008 | 04:56 PM
Default Thanks!!
https://www.jk-forum.com/forums/showthread.php?t=25243
DUDE MAN, THANKS ! ! ! !
