Teraflex 2.5" BB X vs. rubicon
Old Feb 1, 2008 | 05:00 PM
jeepin08's Avatar
Default Teraflex 2.5" BB X vs. rubicon
To start off I have a 2008 X unlimited auto. I installed my TF BB a month ago or so... But during the install of the front spacers I had to use a spring compressor to get the springs to fit.... My question is that I did everything WayofLife did and he didnt use a spring compressor so is the front suspension travel of an x different than that of a rubicon?
Old Feb 1, 2008 | 05:02 PM
BaltChief's Avatar
Should be the same......the springs just fell out for me and I have an X
Old Feb 1, 2008 | 05:08 PM
jeepin08's Avatar
I was able to remove the front springs with a little coersion but it wasn't even close once the spacers were in.
Old Feb 1, 2008 | 05:11 PM
A'sJK's Avatar
interesting
Old Feb 1, 2008 | 05:14 PM
jeepin08's Avatar
I forgot to mention I did add a 1" spacer on top of the TF BB but it still wasnt even close like wayoflife's rubicon
Old Feb 1, 2008 | 06:13 PM
mine were really tight too, especially the passenger side...i only had the 2.5"...it's not a bad thing. just tight enough...i had to twist, turn, pull, push till it sat in correctly. hope you didn't decompress it too much
Old Feb 1, 2008 | 06:20 PM
reynolr's Avatar
I added the additional spacer as well and was definitely tight but still able to get it all back together by myself and with no spring compressor. Of course, I could barely walk for a day or two after finishing.
Old Feb 1, 2008 | 11:14 PM
cormac827's Avatar
no additional spacer but it was VERY tight, used a two by four for leverage to pop the coil in. the fronts were bad, rears were easy enough.
Old Feb 1, 2008 | 11:47 PM
Ctimrun's Avatar
How much did you off road your Jeep before installing the lift? I know WOL off roads pretty hard, even when his was stock, so it is possible his springs were a little more broken in when he installed his first lift. Of course I could be way off here, but it is what came to mind when I read this thread.
Old Feb 2, 2008 | 03:48 AM
jkkat's Avatar
On our 07 Ruby, She had been wheeled some and the front spring faught me in the driveway and the rears were fine.
On our 08 Little Red Ruby, we put in the lift with 150 miles on her and the front fell out and the back faught us on the lift.
Kat
