285/75r16 Duratracs on 2012 JK Sport Stock 16"x7" Steel Wheels?
Old May 21, 2013 | 06:55 PM
Ripley's Avatar
Default 285/75r16 Duratracs on 2012 JK Sport Stock 16"x7" Steel Wheels?
Has anyone tried to run this setup?
What problems did you have to face in the process?
Will Discount Tire even consider mounting this size tire on the stock steelies?
Old May 21, 2013 | 07:03 PM
Watercop's Avatar
I ran/run them on my 2010 & 2012 on stock rims until I got new wheels. Live them. Nice bold look. Only problem I had was slight rub on sway bar at full lock. I just adjusted steer stop with washers. I run them at 35psi and it rides great. They now have 17k miles on them and still look new. Just make sure to rotate them.
Old May 22, 2013 | 04:18 AM
lowendrider's Avatar
I don't think Discount Tire will mount a 285 on a 7" wheel. In fact, most shops won't. You may be able to find a smaller shop that will. I've seen people run that combo and it seems to work fine, even though the wheel is "technically" too narrow for them.
Old May 22, 2013 | 09:14 AM
Ripley's Avatar
Thanks for your help. Just trying to gather more info before I move ahead.
Old May 22, 2013 | 12:35 PM
windellmc's Avatar
They may be hard to balance with the narrow wheel.
Old May 22, 2013 | 01:29 PM
GentleGiant's Avatar
I'm running 285/75/16 Bigfoot XT on my stock JK without issue. This is my 2nd set and Big O Tire never said anything putting them on.
Old Aug 1, 2013 | 07:57 PM
Westtexasjku's Avatar
im running 315/75 r16 on my jk steelies
zero issues AT ALL
running that size on those wheels on my trailer too
i wheel hard and its a daily driver too
ive run those tires for 23k miles
285's will be fine
go for it!
mine are 10 ply load range E mud tires and they are easy to balance
not much weight added it all
ID:	484290Click image for larger version
ID:	484291Click image for larger version
ID:	484292Click image for larger version
ID:	484293Click image for larger version
Old Aug 2, 2013 | 09:22 AM
Ripley's Avatar
Default Duratrac
zero issues AT ALL
285's will be fine
go for it!
Attachment 484290Attachment 484291Attachment 484292Attachment 484293Attachment 484294
Thanks for the input. I'm slowly putting things together, will be checking with dealers soon to see who may mount the 285's for me.
I wouldn't be devastated if I have to go with 265/75/16, but prefer the 285s if possible.
Thanks again!
