Gear question. I thought i knew what i had.
Old Jun 4, 2013 | 09:47 PM
bombout800's Avatar
Default Gear question. I thought i knew what i had.
So at 70 I think I'm at around 2200. The gear table on here shows with 3.73 I should be at like 2000 or 2100. I'm over that for sure. I bought my jeep used and I have my procal set at 3.73. Any chance that could be set and still run a 4.10 gear? I wouldn't think so, but if so I need to change my procal!! Any insight would be helpful!!
Old Jun 4, 2013 | 09:53 PM
ronjenx's Avatar
Jack one tire off the ground.
Rotate it by hand exactly 2 revolutions while counting the drive shaft turns.
That number will be your gear ratio.
Old Jun 4, 2013 | 09:58 PM
bombout800's Avatar
I was looking for the easy answer!!! Haha I guess I'll just have to do it.
Old Jun 4, 2013 | 10:13 PM
nthinuf's Avatar
Using mfg's spec'd tire height instead of actual measured height?
Old Jun 4, 2013 | 10:20 PM
bombout800's Avatar
Well I know my tire height is dialed in on my procal. I went through a few different GPS and radar signs and its on the money every time.
Old Jun 4, 2013 | 10:32 PM
nthinuf's Avatar
So you haven't measured, correct? And you don't actually know which gears are installed? If either of those are different than what you 'think' they are ...
Old Jun 4, 2013 | 10:45 PM
bombout800's Avatar
Correct and correct
Old Jun 4, 2013 | 11:29 PM
jadmt's Avatar
JK-Forum Ambassador
what size tires? those rpms at 70mph look close to what I was seeing in a 2012 jk with 3.73's and stock 255/75-17 tires. my 2013 jku with 285/75-16's show 2000rpm at 70mph with speedo spot on via procal and gps.
Old Jun 5, 2013 | 12:11 AM
bombout800's Avatar
35" nitto trail grappler mt
